SailNet Community - View Single Post - 1968 morgan 30
Thread: 1968 morgan 30
post #4 of Old 11-05-2009
mitiempo
mitiempo's Avatar
I think if you are properly prepared you create most of your own "luck". Check the swages for signs of corrosion or possible cracks - most older boats have older rigging - some as old as the boat. A magnifying glass helps. If you don't know whether your mast step is all glass or not, investigate - success comes from knowing your boat inside and out. Old isn't bad, just needs maintenance sometimes.
Brian
mitiempo is offline
