Thread: lazy jacks
  #25 (permalink)
Old 11-05-2009
osirissail's Avatar
osirissail osirissail is offline
osirissail is on a distinguished road
Originally Posted by dbruce85 View Post
Here is a link for a DIY Lazy Jack system.
I only wish I had seen it a couple years ago when I had my mast down
DIY EZ-Jax
- - It depends upon the length of your boom as to whether you need two, three or 4 lines terminating at the boom. You want enough "capture" lines at the boom to contain the sail on the boom and not allow it to fall between the lnes off the boom.
- - I would suggest though that you substitute the littlest blocks from Schaeffer or others - for the "rings." As you sail and use the system the "rings" will chafe through the other lines. The little blocks will allow the lines to move as necessary without any chafing.
