This boat is over 11' on less than 11" of blocks you could save a bunch if you start taking off pulpits and hang the mast on the side
The rub rail is 8' to give you some scale
Your gonna have to think about height issues if you put it on a cradle without having a lowboy trailer as standard trailers are about 24"
On are local hyd boat moving truck the keel is only 8" off the highway and a 4'5" draft boat is still close to anything that may not be hanging a legal height
You will need permits for each state and what are you planing on using for a trailer as the DOT will take notice of you as the boat and trailer will be in the 12000# +++ range which will require and F350 truck at the very least
You will also save a bunch of money jsut looking for a used JOWI steel cradle as it will ROCK SOLID and fit the boat correctly
And my 29' is 8000# ++
