Old 01-30-2006
RichH's Avatar
RichH RichH is offline
RichH will become famous soon enough
Grease for seacocks
Use a waterproof grease such as Lubriplate waterproof wheel bearing grease. I
f you are ''reworking'' tapered plug type of valves, the ''clamping pressure'' to be able to turn the plug in the valve is by ''feel'', the lock/jamb nut that ''locks'' the spindle nut should be ''very tight'' .... using two wrenches when tightening. Just be sure to not sqeeze out all the grease from the mating surfaces of the plug when tightening ... a little ''drag'' when turn is OK but if you tighten so there is a lot drag/ftiction - will soon push out the grease during normal operation ..... and the plug can stick.
Modern ''ball valves'' usually have a teflon ''seat'' and these dont need to be lubricated, although its a good idea to sometimes disassemble the valve and clean/inspect the stainless ball for smoothness and lack of ''pits'', cracks, etc. When a ball valve starts to leak, etc. its better to simply replace as its damn difficult to ''true'' up ball by hand ... and they are relatively cheap.
