You might also check and see if it will fit inside a cargo container; if it will then you could build a cradle that will roll into the cargo container and then be blocked inside so it won't move. Once inside the cargo box it could be shipped anywhere via truck or train; if the mast is too long you could rig it to tow on a dolly behind a car or truck.
EDIT:
Cargo containers are only 7'8" wide on the interior (max); so it won't work for a boat with 9' beam
