SailNet Community - View Single Post - PSC's on the hard for winter - Drain hole in rudder?
post #2 of Old 11-05-2009
xort
Do you know that you do have water in the rudder or are you just asking about the idea?
If you have water in the rudder, then it would be a good idea to drain it.
Question is...how did it get there?
I have some water in my rudder and I've drilled a small hole near the bottom. It is weeping some water.
Next spring, I plan on cutting out some of the rudder where it meets the rudder post (a bevel) and then use 5200 to seal it up tight. I may try to get some thinned epoxy to flow down into the rudder along the post prior to sealing up the joint.
BTW, not a PSC but I do have a foss foam rudder. Does PSC use the foss foam rudder or similar?
xort is offline
