SailNet Community - View Single Post - Question re: Cal T-4 with rotted plywood under the deck
post #4 of Old 11-07-2009
Waltthesalt
I've seen a number of published articles on doing this. They all did it from the top. Cuttiing out the fiberglass section, replacing the wood then fiberglassing the panel you removed back in. I'll look for the refreences. The issue with doing it from the inside is aparenty doing the glassing upside down. I think that the Gougeon handbook address this and the bevel needed to proplerly glass in the joint.
Waltthesalt is offline
