The cast iron keels on the Rush and Cal 9.2 have pockets on each side of the keel that the studs extend into and the studs have washers and nuts on both ends. Only the leading and trailing studs are into threaded cast iron.
As of to the gap that you have, I'm an epoxy fan even if you consider it temporary.
keelbolts
