Originally Posted by Builditjose
What I see as a concern regarding the stanchions is the ones in my 30' call are mounted on the deck inboard of the toe trim. That reduces my walking area by 5" don't appear much, but in a dry run it makes a difference when freed up. I am considering buying or having build through the hull side monting stanchions that would bolt 2" below the rub rails. They would be 3" wide by 5" long 1/4" plate with 1" tube soket wellded along the center of the 5" lenght of the plate. It would have four through bolted mounting bolts with a 1/8" backing plate. All bolts will have appropriate size washer on the inside. the stanchions will be 36" long by 31/32" held in place with through bolt and lock nut. The stachions will have two safet SS wire. After installation the Stanchions should be 25" above the deck. Please comment on my idea as I am seriously interested in increasing the walk area from cockpit to bow on my boat. It allows me to have greater balance. Thank you
Here's how it's done on Pacific Seacraft vessels, with 30" stanchions mounted horizontally to raised bulwarks, nicely freeing-up the sidedecks:
