It makes no sense to me to buy something this common with bulkheads hacked up UNLESS you feel you can do a good DIY repiar
The real RED flag on the older C27s is the plywood keel sump which can be repaired BUT may not have been and the other issue is a lot of these older boats have raw water cooled motors which is a big issue compared to a freshwater cooled motor (heat exchanger)
I walked away from a 1981 "bargin" C30 with the same issue becasue it had been ignored so long the keel bolts were junk and it had a raw water diesel
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
If a dirty bottom slows you down what do you think it does to your boat To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
