SailNet Community - View Single Post - Electrical draw of autopilots?
Old 11-10-2009
sailingdog sailingdog is offline
LOL... Mitiempo, did you know that is my blog???
Peteris—
I'd second getting a windvane instead of an autopilot. The main reason for this is that a windvane will work in heavier conditions than an autopilot, and not use any amp-hours. In heavier winds, the tiller pilot will use a lot more amps than the minimum and there's much more chance of it failing than a windvane, since the windvane works with more force as the wind strength increases, which is not the case with an autopilot. Also, minimizing electrical usage on longer voyages is a necessity, especially if you're going to be relying on a generator for charging—since fuel is a scarce resource on the open ocean.
