FishManTX—
I'd point out that I have the OGM Tri-Anchor LED light and an Icom M504 radio and have no issues with buzzing or interference.
Just quoting what I found. If you read carefully it sez.."...with those few folks who are experiencing RF interference". Which indicates not everyone has the problem. Unfortunately, Littleflower does. And it's not unique to OGM. But she has a replacement bulb with a standard fixture.
It's more than likely a power/grounding issue, noisy v-reg, etc. This is why placement of the choke is as close to the fixture as possible. If you have a separate driver/supply, put the choke on the cable as close to the supply as possible. Since they are dirt cheap, you could put one on both ends.
I've heard a little bit of bad rep about Dr.LED...
Re: Hella:
Hella NaviLED Trio
about $400
