SailNet Community - View Single Post - A4 Exhaust Raw Water
Old 11-11-2009
tommays's Avatar
tommays tommays is online now
tommays is on a distinguished road
Rich
The A4 is a thermostat BYPASS engine .... meaning if the thermostat is CLOSED (bypassing the flow 'around' the engine) ... the entire flow of water is THROUGH the block. When the thermostat is OPEN, water BYPASSES the engine block.
You have that backwards NO water can flow through the block were in enters through the tee on the water jacket plate When the thermostat is closed other than a small amount through the air bleed hole in the thermostat
It ALLWAYS goes through the bypass to cool the exaust manifold
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
