SailNet Community - View Single Post - hoses
Thread: hoses
post #2 of Old 11-13-2009
RainDog
Not Finished Yet
RainDog's Avatar
I just replaced almost all the hose on my boat. For the raw-water intake I used "ShieldFlex II Marine Water/Exhaust Hose (with wire)". I would use the same for the saltwater pump. Replacing the raw water hose on my boat was a nightmare. The hose runs from the seacock under a series of hoses and wire bundle in the bilge to the locker under the Navstation seat. The hose is under a lot of pressure there, so I think the wire reinforced hose is a must. Getting the old hose out and the new hose in was very difficult, but I managed it by running a wire coat hander through the old hose before pulling it out and then using the coat hanger as a guide to run the new hose. I would strongly advise against pulling the old hose out without some sort of guide for the new hose if you boat is set up anything like mine.
For sink drains and scuppers, I wanted something chemical resistant since you never know what kinds of things will end up in your sink or on your decks when you are doing various boat projects. I had a hard time finding good information on this. In the end I went with Shields 200.
RainDog is offline
