SailNet Community - View Single Post - Stench from Fresh Water Holding Tank
post #5 of Old 11-14-2009
sailingdog
First off, I would highly recommend opening the tank's and pressure spraying the interior if at all possible, then I would replace the hoses and finish by shock treating the whole system per Peggie Hall's directions.
Bleaching or treating the lines won't work very well, since the lines probably have a bioslime coating, where the bleach only affects the outermost layer of it, and doesn't kill all of the bacteria/mold living in it.
I don't recommend adding chlorine bleach to the fresh water system as a matter of normal use, but shock treating it once a season is a good idea.
óCpt. Mal Reynolds, Serenity (edited)
StillóDON'T READ THAT POST AGAIN.
sailingdog is offline
