SailNet Community - View Single Post - Insulation ...
Thread: Insulation ...
Old 11-14-2009
Cal28's Avatar
Cal28 Cal28 is offline
Cal28 is on a distinguished road
Insulation ...
With too many projects on-going (yes I know .. prioritize and complete) ...
one is requiring attention and moving to the top of the list ...
insulation ... for the V berth specifically and the entire boat (potentially)
Again ...the '67 Cal 28 is a test bed for acquiring skills and knowledge as a move up 6-8 feet is planned in 2-3 years ... and it is the San Francisco Bay cold I am primarily concerned about ... and yes ... I am not the handiest bulb on the string ...
There are a few instructional posts on this subject which I have read ... along with much in the forums ...
Capt'n Pauley's Virtual Boatyard -- Projects Galore!!!: Installing Insulation in Your Boat
The Frugal Mariner: Advice for the cash-starved boater -- Insulating your boat
SetSail » Blog Archive » Adding Insulation to Wind Horse
I have come to the conclusion that "reflectix" seems to be the most cost-efficient and easiest way to go ...
My specific questions are ...
V berth (primary focus for the moment)
- two layers sufficient/required?
- what about adding polyethylene foam between between the layers?
- can the "reflectrix" be set directly against the hull ... or should there be an 'air pocket' left ... (the insulation is to be covered in fabric for a more aesthetically pleasing feel and look)
- if so, can it simply be caulked on?
- should the below water level areas (accessible via storage compartments) be insulated to a greater degree?
- any ideas for the anchor locker?
There is currently condensation build-up above only (marine plywood fiber-glassed over) and I have concerns this will continue even if I add a small dehumidifier ... what precautions can be taken to resolve this issue (again ... insulation to be covered in fabric ... but this piece not being done immediately as I have to reset the safety stanchions per Maine Sail's informative guide ... (another pressing project)
Re-Bedding Hardware Photo Gallery by Compass Marine at pbase.com
(yes I read it for the photos ... unashamed)
as if I am not asking enough ... will continuing to insulate the hull ... especially in the cabin and aft berth areas ... help in keeping the chill from my feet (still 40 years removed from humping in the boonies ... rather sensitive to wet and cold)
Thanks to all for their patience ... time and expertise in replying.
