I see it's been awhile. In case anyone looks at this again. I put two three way automotive gas valves, You old guys should remember these from the old Ford truck days with the tank behind the seat and the other underneath the cab, around $30 apiece and an 12V electric fuel pump $55, inline with the fuel tank outlet. This pump puts out 8lbs. of pressure and has a lift of 24". It is set up to use whenever I do a filter change. Pure pressure no air all the way to the secondary filter bleeder screw. When done just turn it back to straight flow. This is really good when you are frustrated bleeding the system, you always have pressure to the engine.
