SailNet Community - View Single Post - Sailboat Rigging Danger
Old 11-17-2009
donradclife donradclife is offline
Don Radcliffe
donradclife is on a distinguished road
The nice thing about the mechanical fittings is that you can take them apart and inspect for internal corrosion/cracking.
The fact that the fitting which failed was on the upper end of the shroud indicates the problem was less likely to be corrosion related, and was probably either misalignment or the rigging was undersized to start with.
