  #22 (permalink)
Old 11-18-2009
garymcg's Avatar
garymcg garymcg is offline
garymcg is on a distinguished road
You can also unscrew the race that is covering the sprocket bearings and pawls, it may be as simple as freeing a stuck pawl. Just be careful as the ball bearings are loose, and numerous to boot. Once you get it apart it will be self-evident if the pawls are engaging or not. I repacked the sprockets on mine without removing them from the shaft, it's worth a shot and won't cost you anything to investigate.
