Originally Posted by Bene505
That's excellent. Thanks Bubb!
There is very little extra space around the mast-exit hole. The halyard barely fits through. I lost the halyard because I used tape-only to hold the messenger line on. In the spring I may splice the messenger to the very end of the halyard using many "layers" of thread.
Regards,
Brad
Brad, On the bitter end of the halyard starting 6 to 10 inches back. Take the messenger line and start making half hitches around the halyard. Make 10 to 15. pull them tight. If you like belts and spenders, then
get out your sail Needle and Waxed thread and run a few stitches though the both of them before you tape over them.
