Old 11-21-2009
Faster Faster is offline
35 foot boat, we had our mast out, upper and lower shrouds replaced (forestay and backstay had been done the previous year) and mast back in for around $1600CDN (mast in and out was $200)
Our mast had European fittings and there was some fiddling/filing required to get the Tfittings properly in the mast... that was much easier to do at ground level, plus we had a good opportunity to properly inspect everything else (wiring, lights etc)
As Paul said above, the rigger's time is valuable, and it would take a lot longer to do this with the mast up. Take the mast off, you can remove and re-install the rigging and just have the rigger come and set up the rig if you didn't feel comfortable doing it yourself.
1984 Fast/Nicholson 345
