up here in minnesota at the western end of lake superior i have to drain the water tanks. i disconnect the fresh water hoses from the water heater & put them together with a short copper pipe so i don't have to pump the RV antifreeze through the heater. i drain the water out of the heater & pump RV antifreeze through the system using a hose from the water pump to the jug of antifreeze. i winterize the head by shutting the seacock & taking the inlet hose off at the head. i put a hose from the head inlet to the RV antifreeze jug & pump it through the head into the holding tank ( after the holding tank is pumped out ) this puts antifreeze through both sides of the head pump. if you closed the seacock, open it when the boat is hauled so it doesn't freeze.
Liberals are people who care about others. Freethinkers are not constrained by the myths of religion.
