SailNet Community - View Single Post - DIY Barrier Coat
post #2 of Old 11-22-2009
deniseO30
One of None
deniseO30's Avatar
interlux 2000E was what we used on my boat. The largest part of the job is removing the old bottom paint. I had it taken off with 50 grit. big job too! the bond is amazing! I'm just having problems with the new bottom paint sticking, my fault because we didn't sand the barrier coat. Any blisters, or fairing you should do before the barrier coat. it's rolled on, 5 coats is best. it sets up way faster then the instructions say it will. use small batches. We did under the stand locations with 5 coats first. the did the rest of the hull. It's all pretty easy tech wise. just long hours of sanding. good luck!
My last project!
deniseO30 is offline
