SailNet Community - View Single Post - Tohastsu - 8hp 4cycle - tech questions
post #10 of Old 11-23-2009
eherlihy
Learning the HARD way...
eherlihy's Avatar
Originally Posted by tommays View Post
Its a new motor and NONE of the parts should have any E10 issues as they were built for it
Uh, no...
At least not as of 2007, the latest year service manual that I could find;
Fuel and Gasolin
Premium (super) gasoline is highly recommended for TOHATSU motors. Fuel should be a minimum pump posted Octane Rating of 87 (91 by Research Octane Rating).
Gasoline containing alcohole [sic], methanol (methyl), or ethanol (ethyl) may cause;
* Wear and damage on bearings, piston, piston rings, and cylinder liners.
* Corrosion on metal parts
*Deterioration on rubber parts and plastic parts
Note: Engine damage resulting from the use of fuel containing such alcohl(s) is not the responsibility of TOHATSU, and will not be covered under the limited warranty.
Source http://www.tohatsu.com/tech_info/own...dfs/Toh40C.pdf
I had to re-type this, because I don't have Acrobat on this PC. I tried to capture all their mis-spellings (and there are quite a few!)
Tohatsu is not the only outboard maker with a propensity to damage from alcohol with their recent motors.
- Ed
eherlihy is offline
