SailNet Community - View Single Post - Tohastsu - 8hp 4cycle - tech questions
post #12 of Old 11-23-2009
eherlihy
Learning the HARD way...
eherlihy's Avatar
Check the float and needle valve (especially the seat) too.
Are you sure that the gunk didn't just travel up inside the jet? I use a piece of wire wrap wire (available from RadioShack) to push through the jets, and all of the little holes in them whenever I pull one. At the risk of getting critiqued, I admit that I then spray the carb bowl with WD40 to help keep water out until I put the motor back in service. (WD40=Water Displacement formula 40)
eherlihy is offline
