Old 11-23-2009
eherlihy's Avatar
eherlihy eherlihy is offline
Will work to sail. :-)
eherlihy will become famous soon enough
Originally Posted by lizardheadone View Post
Sure appreciate the responses. Did the installers have to do any extra laminate work to get these engines mounted correctly? I wanted to go to a smaller engine but the mounts will not span the original mounts, of course. I am doing the work and sure would like to get it right the first time. I guess my question is: Will a larger engine that has mounts that come very close to fitting the original be simpler to install than a smaller engine that will need laminate work and possible metal work to mount? I know the answer to that question may seem obvious, but I also know that different engine dimensions can throw of alignment enough to warrant more mounting work anyway, no matter how the mounts line up.
look here for a complete discussion.
USCG Licensed OUPV Captain, ASA 101/103/104/105 Certified - Also certified in Recreational Marine Electrical Systems
