Old 11-23-2009
sailhog sailhog is offline
sailhog has a spectacular aura about sailhog has a spectacular aura about
The fuel pump and carb can be in perfect working order, and you can have fuel starvation problems. You need to have a solid column of fuel from the tank to the carb in order to maintain the syphoning effect. May want to look into putting a priming bulb between the tank and your Racor. Charge the line with fuel, and see what happens.
