SailNet Community - View Single Post - Bristol 24 Corsair rudder removal
post #4 of Old 11-25-2009 Thread Starter
Windemere
I ended up having mine done professionally, but they showed me what they did, and there is a hidden fixture at the bottom of the rudder that holds it in place, and to remove it, fiberglass has to be removed to access it, and then it releases the rudder for removal...when done and rudder replaced, you need to fiberglass over it again. I know I once found pictures of this on a 29' Bristol, and now know that it's the same for the 24' as well. If you've googled this like I have, you should come across the same info...good luck!!!!!!
Windemere is offline
