New Method for Bolting Stanchions to Deck?
I had to do some repairs to the deck where my lifeline stanchions are mounted, balsa core got wet, and will be remounting the stanchions. I have already removed all the wet balsa and filled with epoxy so the bases are stronger and there is no way for water to get to core any more.
The stanchions have always been a source of leaks into the cabin which I want to eliminate. I know about using a good bedding compound when bolting them on again but am considering another method. I am thinking of putting the mounting bolts in from the bottom so the threads come out above deck and epoxying the bolts into the deck. This would make a water tight seal around the bolts making it impossible for water to get below. I could then just mount the stanchions with nuts above deck.
I have seen traffic poles and other street sign hardware mounted like this with the bolts cemented right into the base with threads sticking up. If it works in this application exposed to all kinds of weather at all times why not on the boat?
You will regret the things you did not do, more than the things you did.
Get out there!
Saco Bay, Maine
1971 Ericson 29
