If your vise has a wide enough space between the jaws, you might be able to use it to do the same thing. The thing would be to make sure you keep the tools lined up exactly straight, which is easier with the press vertically than it is with the vise horizontally. A 13" press isn't that large. Try it with the vise, but I've used the press so much I couldn't even consider the vise right now. Plus, the press puts a lot of pressure down in a hurry, while the vise must be driven sideways & just isn't going to be as efficient.
If you don't need to set as many snaps & rivets as I've done, the vise could do a decent job. I do a lot of clothing, & sometimes I'll set so many rivets or snaps that I can't imagine trying it with a vise. Your usage may be different.
If you know someone with a machine shop who has a press, maybe that person may let you use it. That's how I discovered the arbor press. It's why I now own one, albeit much smaller. It depends on how many snaps, rivets & other hardware you set as to whether it would be a worthwhile investment for you.
I want to be so famous that drag queens will dress up like me in parades after I'm dead. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
