SailNet Community - View Single Post - 1 inch prop on 25mm prop shaft?
post #2 of Old 11-27-2009
Fstbttms
I don't discuss my member
Fstbttms's Avatar
It's not a good idea to put the wrong size prop on the shaft. The tolerances are close with a proper fit and you risk losing another prop if you try to fudge it. If you're buying new, any local propellor repair shop will be able to supply one with the proper bore.
Fstbttms is offline
