SailNet Community - View Single Post - 1 inch prop on 25mm prop shaft?
post #3 of Old 11-28-2009
bilgediver
Originally Posted by lawsonmitchell View Post
Lost my prop last weekend. After hours of swimming in cold water, it looks like I'm going to have to buy a prop. Can I install a one inch bored prop on a 25mm shaft? Where do I find the right metric prop nut and anode for the old metric prop shaft on my 1972 Dufour Arpege. I'm in the Tampa Bay Area.
Thanks,
Lawson Mitchell
What is more important is the angle of the taper. Find out if the 1" prop has the same taper as you your shaft .
If it has the same taper then the only point to note is it might sit nearer the small end of the taper but there should be no problem.
the taper of some imperial props is 1 in 12 and the taper of some metric ones is 1 in 10 however if you have a 1 in 10 shaft and prop or a 1 in 12 shaft and prop then it should work for you. A good machine shop could alter the taper in the prop to fit.
bilgediver is offline
