SailNet Community - View Single Post - Morgan 41 OI stability
Old 07-11-2001
JeffH
Guest
Posts: n/a
In general, there is not a universal agreement on the range of positive stability for offshore vessels. That said you most frequently see recommendations that the minimum acceptable range of positive stability for an offshore boat is between 125 to 135 degrees of positive stability for an offshore boat. 105 degrees is a very small number and would not suggest a boat intended for offshore work. That is consistent with the structure and construction of the Morgan 41 OI series which I would also say is not consistent with a boat designed for extensive offshore.
