Old 11-30-2009
tommays's Avatar
tommays tommays is offline
Well
A 25mm shaft is .984 So the real issue is the angle of taper they CUT were the prop mounted which in all likelyhood is going to be different than and inch shaft and result in a bad fit if you cant find a metric prop
If you look around a BIT you will find the standard tapers are a LOT different
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
