Old 02-24-2006
haffiman37 haffiman37 is offline
haffiman37 is on a distinguished road
Engine submerged.
If 2-stroke: Hose it down with fresh water to get the salt off, drain the carb for water, unscrew the sparkplug(s), spray conservation oil into the air intake, pull the starting rope several times until the engine is empty of water, clean and install the pluggs and start the engine. Let it run for at least one hour on double oil-mix!
If 4-stoke: In addition change oil and filter before restart and check/change oil after restart. (If oil is "milky" change).
Whatever you do, do NOT let the engine dry before restart! Let it stay in water salt or fresh until you can take care of it!
