SailNet Community - View Single Post - Hydraulic steering
post #4 of Old 12-03-2009
jrd22
Courtney the Dancer
jrd22's Avatar
I don't know that air in the system would cause it to be "stiff", generally it will feel kind of mushy, or skip a bit when you turn the wheel. You might be having problems with one of the check valves depending on the make and model of pump. I had a Wagner pump blow out on us not too long ago, it blew one of the threaded caps right out the side of the pump (and a LOT of fluid of course). Before it went it had started to feel "stuck" when trying to turn back from hard over.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
