Morgan 41 OI stability
Despite the numbers...and numbers do not always tell the tale...the Morgan OI-41 is an outstanding vessel..both for coastal as well as offshore passages. Far to many passages have been made in these boats and most Morgan owners are fanatically proud and attached to their Morgans. Yes, I own one - an OI-33, and while I have just made coastal sailings with it I have every intention of make offshore passages with it.
While these boats may not be the "glitziest" they are stalwart and solid. They may not always sail to windward as we want them to, but that alone is not enough to make me change my mind.
Consider this....if the OI-41''s righting moment is at 105 degrees, how much force does is required to put it at that attitude? I would venture a guess that it would take more energy than it might take to get another boat to 125 or even 135 degrees. Why? The weight factors. I''m not sure of the displacement of the OI-41, but my OI-33 weighs in right at 15,000 lbs "dry". If you compare that to alot of other boats of the same size you will find the Morgans are heavier. And to me that weight translates to stability.
If you are looking to race a boat, or want a real fast cruiser....Morgan Out Islander''s are not the right boat. They are slow but steady...and reliable. I don''t think you can go wrong with the OI-41.
As a question of curiosity: Was it a "Broker" or an owner trying to sell his boat that made the point about the righting moment?
