SailNet Community - View Single Post - Idea for turnbuckle cotter pins
post #1 of Old 12-08-2009 Thread Starter
davidpm
davidpm's Avatar
How to secure cotter pins in turnbuckles seems to evoke a range of advice.
Most people insert the cotter pin. bend the legs back and cover with rigger tape.
Some people say the tape encourages crevice corrosion and makes them hard to inspect. They recommend to tape but bending the legs back and around far enough so they will not catch on sails.
I just saw another way.
The sailor had a piece of Velcro about 6" long and 3/4" wide. Pushed through the end of Velcro and the head sewn in with sailor's thread was fixed a cotter pin. The legs were left straight.
The way it was used is that the pin is put in the turnbuckle hole. The Velcro was wrapped around the turnbuckle. The pin could not fall out due to the circle of Velcro. It was loose enough to drain water. It is easy to remove to inspect.
What do you think?
davidpm is offline
