SailNet Community - View Single Post - Westerbeke 27 doesn't crank
post #7 of Old 12-10-2009
klem
Are you sure the engine is seized and isn't simply hydrolocked? If it has sat with water in the cylinders for long enough, it can sometimes have both going on.
A good place to start would be to pull your injectors and take a look inside. If it is dry, try cranking the engine again. If there is water/fuel/anything else sitting in there, you know you had a hydrolock issue.
Good luck.
klem is offline
