SailNet Community - View Single Post - Idea for turnbuckle cotter pins
post #24 of Old 12-10-2009 Thread Starter
davidpm
davidpm's Avatar
Originally Posted by Sanduskysailor View Post
Bottom line if you put the rig up in the spring and take it down when you haul and leave the settings alone by all means use conventional cotter pins. If you plan on tuning your rig for conditions the wrap pins work very well. I change out my wrap pins about every 3 Great Lakes seasons.
Actually is seems as though you would recommend the wrap pins even for cruisers as they are so easy to remove with no tools in the dark. Yes?
Also I doubt it matters but do you think salt water would be more of a problem?
davidpm is offline
