SailNet Community - View Single Post - help: Comprehensive outboard spare part list
post #3 of Old 12-11-2009
tommays
tommays's Avatar
My 1965 5.5 Johnson ran well into the mid 1980s and it had thousands of hours so if you reseal the gear case and did the pump it should do fine
Your real issue will be If the motor will come apart without breaking when there in the shop it tends to take a lot of heat and care to get one apart
So IMHP anything like a water pump should be taken apart NOW and put back toghter with something like tef-gel on the bolts so IF you have and issue it comes apart with ease as saltwater will make this very hard pretty fast
I am not seeing a fuel pump on the list and its a common item to fail
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
