SailNet Community - View Single Post - Pro/Cons of wood composite construction? repair?
post #2 of Old 03-06-2006
paulk
paulk's Avatar
What are you planning to do with it? It would seem that if you're headed to the South Pacific, for example, it might be easier to screw a patch of plywood over an inadvertent hole in a wooden hull than to try to find someone on Huahine who can weld aluminum. Electrolysis is a constant worry in metal hulls as well. Everything about boats is a compromise. What you compromise depends upon you.
paulk is online now
