SailNet Community - View Single Post - Freeing stuck valves, in water?
post #6 of Old 12-18-2009
christyleigh
christyleigh's Avatar
If they are Maralon I wouldn't try much at all except the intense looking mentioned above .... since they are very cold and brittle now.
If they are bronze... I tried when I had a similar problem ..... some WD40 which may (if the shaft is frozen) or may not do any good from the inside, a bit of heat from an electric paint stripper gun, and some light tapping. Even that only got me limited movement which I fixed at next haul by spraying WD40 up into the valve from outside.
Stan
'Christy Leigh'
NC 331
Wickford/Narragansett Bay RI
christyleigh is offline
