SailNet Community - View Single Post - PSC31 Core Moisture
post #3 of Old 12-18-2009
davidpm
davidpm's Avatar
I've been playing with my moisture meter quite a bit lately. I've noticed that if their is metal the other side of the glass the meter will read off the scale. Is their any chance their is some kind of metal backing plate near the fills. Or maybe the meter is reading the fill tube.
As was mentioned if you pull the fitting you should be able to see and feel wet core in the hole if that is the problem?
davidpm is offline
