SailNet Community - View Single Post - Knotmeter- Clarification needed
post #5 of Old 12-21-2009
JohnRPollard
Moderator
JohnRPollard's Avatar
Bubblehead,
Good advice above.
I'll just add that there's no need to swap out the "blank" and insert the knotmeter impeller just now. Leave the blank in place at least until spring. This will protect it from any possible ice damage, etc.
Next year, you may find as we do that the impeller gets fouled fairly quickly by marine growth. Which means you'll have to clean it often for it to operate properly. You can clean it by diving, or by pulling it out (swapping with the blank). Sometimes, depending where it's located on the hull, it can be reached with a long-handled brush.
FYI, we don't even bother putting ours in any more. It gets fouled very quickly, and we have boat speed (over the ground, anyway) via gps.
JohnRPollard is offline
