SailNet Community - View Single Post - What is a Deck-stepped mast and keel-stepped mast
post #3 of Old 12-24-2009
CaptainForce
CaptainForce's Avatar
The mast "step" is the location where the bottom of the mast is secured. If this step is on the deck, the weight of the mast is usually supported by a "compression post" or weight bearing pole under the deck and transferring this force to the keel. A keel steped mast passes through a hole in the deck and continues to the keel without a compression post. 'take care and joy, Aythya crew
CaptainForce is offline
