SailNet Community - View Single Post - Low Cost General Tools Moisture Meter?
post #2 of Old 12-25-2009
Maine Sail
Maine Sail's Avatar
The readings do you little to no good unless they come with a conversion scale to read fiberglass, which that meter does not, nor do most meters only intended for wood. The CT-33 has specific translation scales for reading fiberglass..
You can not use the chart from one meter to translate another as they all interpret moisture in their own way.. The cost is only peanuts if you are not wasting it...
______
-Maine Sail / CS-36T
Maine Sail is offline
