SailNet Community - View Single Post - oil leak advice
Thread: oil leak advice
post #5 of Old 12-26-2009
Quick Fix
I had a similar problem, the main seal from the motor to the coupler went bad. Auto parts store has an oil additive to fix seals, you put right in your motor. Follow instructions should patch the problem for a time till you can change it. Heavier weighted oil in warmer climates can slow the leak as well.
JoshuaMichael is offline
