SailNet Community - View Single Post - Need advice on engines - Westerbeke 30B or Yanmar 3YM30?
post #8 of Old 01-01-2010
boatpoker
Dirt Free
boatpoker's Avatar
A number of 3YM30's have had overheating problems due to undersized heat exchangers and a smaller raw water pump. Yanmar is aware of the issue and have replaced a number of exchangers free of charge. These issues have been showing up around the 150 hour mark on engines with serial numbers lower than 6000
The fix is to install a 66 tube heat exchanger rather than the original 35 tube unit an use a larger raw water pump.
The hysterical laughter you hear as you drive a way in your"new" boat ..... is the seller.
boatpoker is online now
