SailNet Community - View Single Post - Low buck projects- Let's see 'em!
post #104 of Old 01-03-2010
roline
Cal 9.2 SilverSwan
roline's Avatar
new custom holding tank
I've done many of the low buck dumpster diving projects...
Another problem with the Cal 9.2 is that the holding tank was a VETUS bladder under the V berth. This issues, smell, odor, stench, and low volume..
I designed a custom tank to go behind the head for the shortest lines possible. I looked for Poly tanks, but could not find one that would fit as desired, so I designed one on CAD, did a mock up with the paper backed foam board and packing tape, then taped heavy poly plastic to it and started adding layers of glass and resin, 10 layers total. ( 3/8" thick)The top access hole was cut and the insides were stripped out and the insides finished. The insides were sanded and then epoxied with a smooooth coat and fillets in all corners. ( easy cleaning) I installed with the heavy vinyl hose and redid the woodwork. I was selective on Ebay for the epoxy and cloth always looking for the best price/ deal. The plywood was from the stove slide out shelf project. A couple of pics from verifying fit and finished installation. I had to extend the woodwork outward slightly to pad the tank, an after thought...... ps, over 3 yrs since installation, no odor issues, works great, improved the wife approval factor.
Cal 9.2 #19 SilverSwan
roline is offline
